Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-01-2005, 01:21 PM
Crimin Crimin is offline
Battery Alt Issue?
I have a 95.5 Rodeo that consistently reads around 10V while running on the instrument panel, when i test it with a handheld voltmeter it reads 13.35V which to me says the alt is good, I replaced one of the brushes in the alt last year. The battery is new and everything seems to run fine until I turn on the headlights, then the volts drop way low, and cuts out.
I have read on this forum the volts when running should be 14+ should it really be that high? I also read they don't like rebuilt alternators but if it reads 13.35 is that not acceptable?
Old 03-01-2005, 02:18 PM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
Re: Battery Alt Issue?
Everyone says don't use aftermarket alt.'s because of this issue. I have a feeling if you put in a OEM your problems will go away. More expensive, but how much is your time and frustration worth.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 03-01-2005, 02:20 PM
Old 03-01-2005, 07:50 PM
Ramblin Fever Ramblin Fever is offline
Had this problem all last summer, as I believed my turned-out-crappy alternator was fine.
Do yourself a favor, save the headache and get a BOSCH alternator, along with at least a 750 cold cranking amp battery. This setup has worked wonders for me.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
