Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-01-2005, 01:21 PM
holydvr holydvr is offline
Send a message via Yahoo to holydvr
'98 Wrangler 5 SPD 4x4 Idle Problem
The Jeep Idles Rough, But runs fine above 1000 rpm or so...The Check engine light is on And the computer is Showing a trouble Code For Multiple cylinder misfire...I tuned it up with a new Cap, Rotor, Wires, And plugs...I even substituted a new coil and its no better...I was thinking the Crank Sensor? Or maybe the Pick up in the Distributor?? Any help would be greatly appreciated...I can be reached at my e mail address as well [email protected]..Thanks!
I did erase the codes as I should with the external computer after I did the work, but it didnt run any better and the light came back on...
Old 03-01-2005, 01:22 PM
Forgot to mention
Its a 4.0L 6 cylinder engine...
Old 03-01-2005, 05:05 PM
JeeperRich JeeperRich is offline
Re: '98 Wrangler 5 SPD 4x4 Idle Problem
Try cleaning the inside of your throttle body with carb cleaner -- I was suprised how much dirt had built-up inside mine ('98 4.0L, cleaned it at ~90k). Pay particular attention to the idle airpath. Also, check your O2 sensors (simple voltage check in the Service Manual).
Old 03-02-2005, 01:59 PM
Ill give that a try thank you very much!
Old 03-03-2005, 12:49 PM
Still has the same problem..
Old 03-10-2005, 02:52 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Check all the ground wires going to the engine.
What did the old spark plugs look like when you removed them? Any sign of a head gasket leak?
