Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-01-2005, 09:57 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Access to TSB's?
Anyone?
here is a new one I'm interested in:
# IB04-03-S001 FEB 04 Emissions - Misfire DTC's/Catalytic Converter Damage
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-02-2005, 07:43 PM
txsoulfly txsoulfly is offline
Send a message via AIM to txsoulfly Send a message via Yahoo to txsoulfly
Re: Access to TSB's?
Originally Posted by amigo-2k
Anyone?
Well I finally get to help out the guy who's site has helped me out so much.
HTH
Information IB04-03-S001
Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems
Issue Date: February 2004
Affected Vehicles
2003 - 2004 and prior Isuzu models.
Service Information
It has been determined that aftermarket alarm systems incorrectly installed in vehicles have the potential to cause misfire codes and damage the catalytic converter.
These alarm systems use a circuit interrupt which utilize the ignition circuit on the vehicle, they also utilize mechanical relays and normal vehicle movement can trigger these relays to engage and disengage the ignition circuit while the vehicle is in motion. These disruptions of the ignition circuit, which occur in milliseconds, may cause more fuel to be commanded. Over time, on and off fuel dumping can cause misfire codes and ultimately damage the converter assembly.
Engineering could not identify any alarms that utilize solid-state circuitry that would eliminate this concern. Because of this, it has been determined that all alarm systems must be routed through the starter circuit in order to avoid this condition.
Dealers must be aware of this issue and take note of the wiring on vehicles with alarm systems that come in for repair, particularly for catalytic converter damage that seem to have no known root cause.
Let me know if you need anything else.
Mando
1998 Rodeo S 3.2 3" sus lift, Dueler Revo's, Aisin hubs, and Aussie locker.
Old 03-02-2005, 09:28 PM
Isuzu Guy
thanks for the info!
-Ryan
Isuzu Moderator
Car Show Tips
