Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-01-2005, 02:01 AM
lavaiie lavaiie is offline
Angry 98 contour SE auto transmission problem?
Hi, when pressing on the gas the car will give a hard kick somtimes, it also dose this if i let my foot off the gass when comming to a stop. secondly when i want to accelerate from stoping at a light, the car will stutter at a low speed as if somthing is not catching it dose this for about 5-10 seconds. Any help/advice is appreciated Thanks!
Old 03-01-2005, 08:38 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
when was the last time the fuel filter was replaced?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-02-2005, 12:03 AM
i have no idea becuase i just got the car. the car can go a day without the problem but i did notice a diffrence when i used higher quaility gas, the problem did ease a bit.
Old 03-02-2005, 09:44 AM
does the problem usually occur upon a cold start up and go away once the car has been driven awhile?
"The CEG Nazi"
www.contour.org
Old 03-02-2005, 11:02 PM
its random, somtimes when the car has been running for a while it will start to stutter. upon start up the cold it might jerk but today everything was smooth so i dunno
Old 03-02-2005, 11:42 PM
I think I would replace the fuel filter. Its a cheap fix and literally takes 2 seconds to replace. Its located underneath the car, in front of the passenger side rear tire. You can buy the replacement parts at NAPA or probably any auto parts store for about $20.
"The CEG Nazi"
www.contour.org
Old 03-03-2005, 11:54 AM
Re: 98 contour SE auto transmission problem?
sooo..u dont think its a transmission problem?
Old 03-03-2005, 01:56 PM
Re: Re: 98 contour SE auto transmission problem?
nope.
"The CEG Nazi"
www.contour.org
Old 05-25-2005, 12:20 PM
Questionford Questionford is offline
Re: Re: Re: 98 contour SE auto transmission problem?
Hey, did anyone ever find out what was causing that problem with this 1998 Contour? I see the last post was in March. I am having the exact same problem with my 98 Contour SE. By chance the water pump had to be replaced, but still having that bucking / shudder thing every now and then.
Old 06-23-2005, 09:38 PM
trinity777 trinity777 is offline
Re: Re: Re: Re: 98 contour SE auto transmission problem?
I had a rain (rane?) sensor replaced ina 98 contour. The symptoms were hard shifting, with a lurch, slow take off from a stop. Also had a little trans fluid puke out the breather tube up by the battery. Mechanic did the fix, said the trans didn't know what gear it was in. Wasn't cheap but sure beat a rebuild.
