Old 03-01-2005, 12:04 AM
00blackzx3 00blackzx3 is offline
Good Mods For Low End Power
Ok i have a 94 SL and my torque sucks on this thing. To make things better it is an automatic. I am tired of driving it manually. What mods can I do to make nice low end power? Do they make any kind of ECU chips for our cars or anything?
Old 03-01-2005, 12:10 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Good Mods For Low End Power
How about a v8? lol, umm the only way I can think of adding low end power would be pistons, maybe some headwork, or underdrive pulley. Everything else is aimed at HP and mostly just raises the RPM at which the max torque comes.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 03-01-2005, 02:54 AM
Im2Fast4U Im2Fast4U is offline
Please tell me you don't mean shifting it from 1-2, etc...... Don't do that.
Nope. Well I guess technically there are some made but they don't do anything and aren't worth the money. And yea, I'm not sure on too many mods for low end specifically. All the basic BPU stuff tends to raise the power band... just perfect brake torqueing
1993 Dodge Stealth
yes, it has mods....
R.I.P. DAD NOVEMBER 3, 1952-NOVEMBER 25, 2002
I LOVE YOU
Old 03-01-2005, 01:53 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
torque? plenum spacer! that will move your torque peak earlier in the rpm band, but by only maybe a few hundred rpm. it goes between the upper intake plenum and the lower intake plenum. you should replace the plenum gasket as well (as you'll need 2 instead of 1, one for each side of the spacer).
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-01-2005, 05:43 PM
Old and good Old and good is offline
Send a message via MSN to Old and good
most n/a mods tend to make more tq in adition to the hp but i have heard good things about hedders shorty headers to be spesific as they make loads of tq but in the 3s cars im not to shure that you can make long tube headers anyways or at least not without a big headace
plenum polishing can also make more hp and good tourqe.
the rule of thumbs is of course the bigger the displacement the bigger the tq so you culd perhaps increase the displacement with borig or replace the 6g72 engine with a 6g74 i saw some guy on the net doing that to his car
Old 03-01-2005, 07:14 PM
Hotshot8792 Hotshot8792 is offline
best thing for torque on an automatic is a high-stall torque converter
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 03-01-2005, 07:40 PM
where can i find a high stall torque converter ? How much do these typically run? installation costs?
Old 03-01-2005, 09:17 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
How does the plenum spacer work exactally? Where can you get one?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 03-01-2005, 10:20 PM
Igovert500's Avatar
blue + red light magnet
I still say plenum spacers are a mod that should be saved for carburated engines. Yes they cool down the plenum temperatures, but IMO, not the best for fuel injected engines. Feel free to post disagreements, like I said, just my .02
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
