Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 03-01-2005, 12:00 AM
Televisor Televisor is offline
My Dash lights dont work!!!
Hey I have a 2002 Malibu and I dont know why speedomter and dash lights wont come on at night. Also, the radio display turns off. The radio display will come on during the day but the speedomter or tach lights wont. The door button lights also wont come on. I've tried the dimmer button but it didnt work.
Old 03-01-2005, 06:47 PM
dolluper dolluper is offline
Re: My Dash lights dont work!!!
Sounds like your door switch is not grounding or wire has come off [as you called door button]
Old 03-14-2005, 09:15 AM
bromark bromark is offline
Send a message via AIM to bromark Send a message via Yahoo to bromark
I had a similar problem on a 98. It turned out to be a ground problem. The ground for the body is located in front of the battery (two wires going from the battery to the body) The small bolt was rusted and look burned and when I took it out the threads in the nut were almost gone so I welded on a new nut (I drilled the orginal out to accomidate the new bolt just passing through it) and all my problems went away.
Mark
