Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-28-2005, 09:46 PM
av.sig av.sig is offline
96 Rodeo no pwr to blower motor or switch
Hi
The blower motor in our Isuzu quit. I checked power on the blue and white wire with the switch on, and got nothing. I checked the fuse its good. I checked power at the fuse, and got nothing. The dashboard switch is good, after a continuity check. The other posts say it may be the blower motor resistor. Am I on the right track? Any other suggestions? Pleeeeeeeeeeease Help. After I get this fixed I have to figure out how to put the vent cables that I broke back together. (oops)
Old 02-28-2005, 09:55 PM
9passport7 9passport7 is offline
Re: 96 Rodeo no pwr to blower motor or switch
if you don't have power at the fuse you need to check backwards from there
Old 02-28-2005, 10:31 PM
amigo-2k amigo-2k is offline
Isuzu Guy
a search for blower i came up with
http://www.automotiveforums.com/vbul...ghlight=blower
2eyefishclaw:
you may want to consider checking the blower motor resistor behind the glove box in the blower housing
looks like this would be something nice for a 91-97 faq ....
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-01-2005, 05:30 PM
Re: Re: 96 Rodeo no pwr to blower motor or switch
Thanks for helping me. I discovered that the only way I have power in the blower circuit is when the engine is running. My "Haynes" book says when check power on the blue and white wire, the engine key should be on but the engine shouldnt be running. Is this something to be concerned about? I do have a resistor on order.
Old 03-01-2005, 05:32 PM
Thankyou.
Old 03-01-2005, 11:02 PM
GMW72 GMW72 is offline
I just had the same problem fixed yesterday. It was the blower motor and the resister. My mechanic says that Isuzu/Honda say that you should replace both parts or they will not honor any warranty for the new blower motor.
Old 03-02-2005, 07:42 AM
Thankyou.
