Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 02-28-2005, 09:42 PM
noctorum noctorum is offline
Launches
How do you all launch? Any guides online?
When you rev, do you hold down the brake, or leave your clutch disengaged?
Old 02-28-2005, 10:06 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Launches
I have an automatic Grand Am. For my launches, first of all, I turn off ETS to disable the possibility of it cutting timing when it detects wheel spin. Secondly, I put the selector in 3rd to lock out overdrive. Then I hold down the brake with my left foot, rev it up to about 1500 RPM, and then let off the brake and gradually feather in the throttle to prevent spinning, and after I get to a certain point (about 15 MPH) I'm able to give it WOT.
Old 03-27-2005, 06:43 PM
tr0ike's Avatar
tr0ike tr0ike is offline
Send a message via AIM to tr0ike
Re: Launches
I hope those weren't supposed to be exclusive options?
I put the clutch in, raise RPMs to about 3000 revs, then proceed as normal - except perhaps dropping clutch / hitting gas swifter than normal driving.
3UR0
I roll in dubs, not on them
Old 03-29-2005, 05:17 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Launches
makes its dependence on the car, as some cars need more clutchwork than others to launch.
RX-7 TII
Old 04-01-2005, 08:58 PM
PWRDbyUNCLEbens's Avatar
PWRDbyUNCLEbens PWRDbyUNCLEbens is offline
Ditto every car is different even more so for manuals. In my car which has a 2.0 liter 4 banger front wheel drive I get the rpm's to around 2600 and let out the clucth. If I feel my tires slipping when I let out my clutch, I feather (toggle) the clutch until I can get enough traction to go WOT. Dumping the clutch works if you know the perfect rpm to launch at, and can get traction back quickly, but it's not the best method. You really have to practice. Do what you do in daily driving from a stop, and just turn up the wick until you find the right technique.
1992 Sentra SE-R: Bluebird SR20DET @ 10psi, 3" exhaust, FMIC, Poly-Urethane Motor Mounts, Centerforce (slipping) Clutch, Tein SS coilovers, FSTB, RSTB, 205/50/15 Hankook RS2's
Old 04-01-2005, 09:09 PM
drftk1d's Avatar
Re: Launches
for example my car has no torque so i have to drop it at 4k (with good traction, no less).
RX-7 TII
Old 04-01-2005, 09:25 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: Launches
IF u have a AWD car u can have really fun launches Hehehe push in cluctch raise to 5-9 depending on your car and let it go and hold you steering wheel and you a**
Old 04-02-2005, 08:38 PM
tr0ike's Avatar
Re: Launches
Hey, sorry for the OT, but is your Sentra an 8V or 16v? What's your redline/peaks? Curious as my car is also a FWD 2.0L ... but being a VW its more torquey and less powerful than a lot of Japanese 4cyls.
3UR0
