Go Back   Automotive Forums Car Chat > Fabrication & Tools > Fiberglassing
Fiberglassing Fiberglasssing explained and the proper techniques on working on a fiberglass project.
Old 02-28-2005, 09:00 PM
Powerefx Powerefx is offline
Attaching two bumpers.
Hey guys i have a question, I currently have a car in which i want to put a body kit on, its an escort wagon. The thing is, no one makes the rear bumper for these cars. I just measured and found out that a 92-95 civic 4 doors bumper can be made to fit mine. I was wondering how i can go about attaching the two bumpers. Do i weld them together and how would i doo this, or is there another way, like just overlapping the twoo with bondo(dont think this way will be sturrdy). Please help me and give me step by steps if possible. thnx
Old 03-01-2005, 02:38 AM
Devious Designs Devious Designs is offline
Send a message via AIM to Devious Designs
Let me see if I got this right, you want to take a honda bumper, and cut it to make it fit onto the existing bumper? How much material are we talking about adding? Deffintly don't use bondo....
Old 03-01-2005, 07:45 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Attaching two bumpers.
Definately cant weld fiberglass. Use some screws, and fiberglass. It will be a lot of work to make it look right.
-Mike
Old 03-01-2005, 10:05 AM
Ya i was leaning more toward fiberglassing over the two. What about these screws, wont the screws show on the bumper. Also if i fiber glass do i just layer a little resion on the inside, then chop mat, then resin again? Should i do it on the outside as well?
Old 03-02-2005, 10:14 AM
anyone?
Old 03-02-2005, 12:47 PM
mike@af's Avatar
Resin is mixed into the fiberglass, not applied separately. You take your resin mix it in the glass and lay the glass down. The screws should show through if you know where to place them.
-Mike
Old 03-02-2005, 08:08 PM
I dont quite understand what your trying to say, can you simplify it in a step by step?
This is what im getting from what your are saying and im pretty sure i didnt get it right.
1.screw the two together
2.take fiberglass(chop mat) and mix together in container with resin, then aplly mixture over the screws.
Is this correct or what?
Old 03-02-2005, 08:40 PM
mike@af's Avatar
Let me say this first. This is no little project, that is going to be a lot of cutting fitting and fiberglassing no matter how close it looks.
I suggest you do a lot of reasearch and practice with fiberglass before attempting a project of this caliber. Because if the glass isnt under the right conditions it will become brittle, crack, not adhere, so on and so forth.
I'm not trying to be an ass, but trying to help you.
-Mike
Old 03-02-2005, 08:48 PM
I noe its not gonna be easy, all i asked was how will is it done, i already noe its hard and i need practice with fiberglass, i just want to now how i should it be done.
Old 03-02-2005, 09:05 PM
mike@af's Avatar
Take your epoxy resin and hardener and mix them together evenly. Lay down the fiberglass on some sort of plastic mat like a trash bag. Pour the mixed resin on the fiberglass and use an old paint brush to spread the resin through out the glass. Then apply the piece of fiber glass.
-Mike
Old 04-21-2005, 08:09 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
i'm i'm correct, pimp my ride did this to an escort too. i'd fiberglass the inside and outside for added strength.
95 Talon TSI AWD
97 Eclipse GST
