Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 02-28-2005, 07:30 PM
gregwal gregwal is offline
Question Brake Light indicator on very dim
I have a 95 Aerostar and the red brake indicator comes on at times very dim. After I cleaned the contacts at the brake fluid res. It went away.
Does anyone know if the wiring that attaches to the resevor could cause this problem
Old 04-03-2005, 01:36 AM
LoudMouth LoudMouth is offline
Re: Brake Light indicator on very dim
If you cleaned the contacts and it solved your problem (even if only momentarily), it is possible that a thorough cleaning may be necessary (use sandpaper or a flat blade screwdriver to scrap away any rust or corrosion).
Yeah I Know What I'm Talking About !
