Go Back   Automotive Forums Car Chat > Buick > Grand National/GNX
Old 02-28-2005, 05:49 PM
s.pliskin s.pliskin is offline
Unhappy headlight issues
greetings
I have an '83 Regal and I posted this question in the regal forum, but, after 22 views and no responses I decided I'd come over here.
My problem is, that when I first got the car, the highbeams would flash ( like in a police cruiser) on and off, on and off, but, the low beams worked ok. However, now, the low beams flash when I use them, so, I have to use the high beams, which DON'T flash now.
I have no idea what is causing this.
any suggestions?
thanx
~S
Old 02-28-2005, 06:02 PM
gnfreak's Avatar
gnfreak gnfreak is offline
i'd check the switch
dont know how much help i'll be but...
that does sound real strange. i would personally check the switch first. i just replaced a swith in my kids 97 s-10 that messed up that took me two weeks to find cuz i made it harder then it was. get access to the switch, find out which wire is which and apply 12v directly to the highs or lows and see if you still have flashing lights. hopefully its an easy fix. if you still have flashers then start checking wires. really strange that it switched from one to the other. good luck
Keith LaCombe
Normal, Illinois
[email protected]
1986 Buick Grand National
1997 Chevy S-10 (daily driver)
2003 Chevy Trailblazer (wifes SUV)
1993 Chevy Camaro Z28 (kids car)
Old 02-28-2005, 06:09 PM
I'll try it
hey thanx for the reply timely reply!
I'll try it, but, I'm thinkin I may have to have a special tool to pull the steering wheel off?
~S
Old 02-28-2005, 10:43 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
I do know that thoes shitty GM cruise, signal, brights, wipers switch always goes bad. Could be that as well.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-28-2005, 10:44 PM
Hypsi87's Avatar
Re: I'll try it
~S
yea that tool is like 30 bucks at advanced autoparts.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 03-04-2005, 10:33 AM
ok, ok
I guess I'll just go ahead and replace the switch.
My steering column is loose also, it is tilt wheel, but, it's loose.
Also, the shifter wants to keep going into 2nd gear when I take off hard, guess that could be caused by the loose/weak motor mount?
thanx
~S
