Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 02-28-2005, 03:47 PM
harpafou harpafou is offline
17'' on 99 passat
I own a '99 passat. The standard wheel size is 15'' with the option of 16s. Will 17'' wheels fit without altering anything else? Starting in 2000 I believe passat had the option of r 17''. What changed?
Specifically, I wanted to put the VW "santa monica" wheels on my car if it will work
Thanks
Old 03-01-2005, 12:15 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I believe up to 19's will fit.
w8 passat uses 18'' rims.
Old 03-02-2005, 03:40 PM
00Psst's Avatar
00Psst 00Psst is offline
Re: 17'' on 99 passat
Thanks
17s will be no problem - most of the 17 inch wheels will be either 7.5 or 8 wide so no worries at all. You can fit 18s without much issue as well depending upon how much of a drop you have in the suspension. 19s and up are trickier - if you're dropped, you'll need to roll the fenders. Here's mine on 17x8 Alessios.
