Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-28-2005, 01:56 PM
rendertrust's Avatar
rendertrust rendertrust is offline
head gasket !
well when i revv up white smoke comes out and im pretty sure its due to a faulty head gasket .. anyways i was wondering whether a leak in a gasket can cause a loss of compression which equals loss of power ? that wayi can have a rematch with the CL
Old 02-28-2005, 04:45 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: head gasket !
yeah a bad head gasket will cause a lot of loss in power...and the white smoke. but there are a couple more things that can cause white smoke to come out of your exhaust...warped head being the biggie.
and replacing the head gasket is not an easy job so if you plan to do it yourself, look to curse a bunch and if you are having it done, look to spend quite a pretty penny.
if you have a blown headgasket, usually your heat guage will go up meaning your car is overheating...
ZedEx Crew Member #4
Old 02-28-2005, 05:01 PM
Re: head gasket !
well the gauge stays normal, but if you drive for an hour going over 40 then when you step out of the ar you feel the heat ... when i checked the coolant level about 4 months ago i found there wasnt any so i put some in, i guess that would be a sign that its leaking, the white smoke only comes out at higher rpms so i would think this elimantes the possibility that it could be a head because wouldnt the smoke always be coming out no matter the rpm level ?
Old 02-28-2005, 06:09 PM
Z Cars Fanatic
Re: Re: head gasket !
well its coming out due to more pressure in the engine...casuing the water to squeak out...which means you have a minor leak.
you havent checked the coolant in 4 months??? you should check all your fluids atleast once a week. i usually check all mine everytime i put gas in it...
anyways, keep it filled with fluid and get it taken care of ASAP before you end up with a bigger problem...
Old 02-28-2005, 06:10 PM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
Re: head gasket !
... Well no.
Think, when you increase motion inside a combustion chamber, meaning MORE exhaust gas is MOVING around.
So if you have more gas, it will push more out, and not hold proper compression.
If you have a faulty head gasket, sometimes it doesnt wear all of the way, and it only comes out past idle.
But if it is your head gasket... Good luck paying for that. Hate to say it, but it's the honest to God truth. It will be WAY up there.
Good luck dude... Thats the bad part about owning a Zed32.
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
Old 02-28-2005, 06:15 PM
Z Cars Fanatic
-Wes
yeah, dont be fulled by the cheap price of the head gaskets...labor is gonna kick your a**. how many miles are on your motor???
just for reference sake, you can get a nice JDM low mileage N/A motor for like $800. and if you shop around you can find someone swapping an N/A for a TT and pick up there N/A motor for like $500-$600 bucks which might be cheaper than replacing your headgasket.
Old 02-28-2005, 06:58 PM
Re: head gasket !
well my uncle will do it for cheap, he worked on my car before .. he wouldnt charge me more than 100$ for anything except an engine swap, but i think i want to do it on my own even though i have never worked on motors in my entire life .. its never to late to learn, reminds me i need to get a service manual
by the way how much hp do you think im losing thanks to the leak ? like 10 horses but all the loss is at the top end
Old 02-28-2005, 11:39 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
Re: head gasket !
i dont know but your losing power.... dang your uncle will charge you $100 tell him since your family too hook it up better then that lol good luck with the Z ....
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 03-19-2005, 11:31 AM
pbshadowkiller pbshadowkiller is offline
Send a message via AIM to pbshadowkiller
Re: head gasket !
yep i had a 94 tbird and it had a blown head gasket and you could smell the antifreeze burning after it had been running for a while. check your plugs and see what the look like cause mine had the antifreeze and oil mixing in the clys. good luck with everything.
Old 03-19-2005, 03:49 PM
Z Cars Fanatic
it was a 6cyl wasnt it...that damn ford 6cyl was notorious for going through headgaskets. i had a mercury cougar that blew at about 80k miles.
Old 03-19-2005, 07:16 PM
Bdetore Bdetore is offline
Re: Re: Re: head gasket !
Does anybody know that nomatter what the extent, you shouldn't drive with a blown head gasket? Simple math kids.
Old 03-19-2005, 07:33 PM
Z Cars Fanatic
Re: Re: Re: Re: head gasket !
yeah, thats pretty obvious. hell, i couldnt drive my cougar if i wanted to. it would over heat in a matter of minutes. i just drove it from school to my house which was about 5 blocks. replaced the gaskets and it was as good as new...
anyways, rendertrust, go get your headgasket fixed by your gramps...
Old 03-20-2005, 02:05 PM
Re: head gasket !
no it was a 4.6 motor not 3.8 but my buddy had a 3.8 and he replaced the gasket for about 500
Old 03-20-2005, 03:26 PM
Z Cars Fanatic
damn ford!!!
Old 03-21-2005, 02:18 AM
liam91ttz liam91ttz is offline
Send a message via AIM to liam91ttz
Re: head gasket !
my z32 is sitting out front of my house in the street just chillin, cause i think the head gaket has blown, i havent driven it at all since then
but start it up every couple of days it fires every time .
but i noticed alot of white smoke throught the hks cannons of exaust pipes.
it was running fine with over heating exept wehn my over flow tank went n i drove it overheated bad for about a couple of miles till i eased her home, ( last time i drove it) could i have warped the heads when this happened?
also there was knocking through the exuast when i tried to open it up, stopping the car to pull alltogether(the start to all my problems) which i think blew the gasket
now when i fire it up just to start it it idles at 2 or higher before slowly coming down sounding kinda rough.
how much did u pay for head gaket in labor?
91 300zx twin turbo stage 5
[B.] Past Z Car Crew [/B.]
