Old 02-28-2005, 11:54 AM
sbrider sbrider is offline
zc engine swap trouble
I recently swapped a zc engine into my 91 civic. It started and ran fine for several hours, lots more power. After driving it a while it started to stumble on acceleration. It seems to run better when it is cold, but it still isn't right. Once its warm it bogs really bad. The ecu is flashing a code 20 (electric load). Under the drivers dash there is a quiet beeping type sound when I turn off the ignition. It seems the wiring is wrong but I checked and it looked good. If anyone's got some Ideas of what I might check or try the info would be appreciated.
Old 02-28-2005, 12:09 PM
mrceej mrceej is offline
Re: zc engine swap trouble
If you didn't solder your connections, you should. I had trouble with my swap (not the same as you are describing). But in the end, it was because of the butt connectors that were used in converting the DPFI to MPFI. After everything was soldered, all was good. Hope this may useful in your situation.
Old 02-28-2005, 12:40 PM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
look for the ground wire near the thermostat. make sure it's tight... or look at the TPS it may be bad test it.
1989 honda civic hatch Standard model Gutted
(1650 lb)
Freshly rebuilt ZC
2.5 exhaust
(2) 10lb bottles of juice
75 wet shot
lightweight crank pully
ZC tranny W/ SI final
8lb flywheel
Dual force p.p.
ACT clutch
2.5" drop
cheap tires
cheap rims
projector headlights W/matching corners
20% tint
semi-flat black paint (hotrod black)
