Old 02-28-2005, 12:22 PM
cc rider cc rider is offline
1998 3500 Crew: squeaking front suspension...
... is driving me crazy! 7.4 L, 130K miles. She squeaks and groans whenever the springs get loaded: turning away from the curb, speed bumps, etc.
I've sprayed silicon on every rubber thing I could find: A-arm bushings, shock mounts, swaybar hardware, etc. The squeaking might be reduced (but not eliminated) for a day or two, then it comes back. You can hear it a block away.
My next attempt will be: remove swaybar and test-drive. If that doesn't work: remove springs and inspect/replace the isolators. After that: take the whole front end apart and replace all the bushings.
If you have any info on this problem, PLEASE let me know before I go that far.
Thanks!
c.
Old 02-28-2005, 09:17 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1998 3500 Crew: squeaking front suspension...
My shocks are starting to go, and make a squeaking sound when going over speed bumps. How old are your shocks?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-01-2005, 10:32 AM
Good question. I'll check it out. We bought the truck used, with a lot of miles, and it was in a wreck at some point. New shocks wouldn't hurt regardless. I still think it's more than that though. It is really freakin' loud.
Thanks!
c.
