Old 02-28-2005, 10:25 AM
95cord 95cord is offline
swap question
about 2 months ago my wife bought me a 1999 si that had been wrecked. i pulled the motor and tranny(b16a2 only 25,000 miles) had i/h/e on it. stripped the interior. it also had buddy club adjustable coil overs. for the past two months i have been debating on putting it into a 88-91 crx or a 92-95 honda civic.
heres my question for you guys.
1- can i use the hydro tranny in the crx if so how hard will it be to swap from cable to hydro
2- can i use the adjustable coilovers
3- which would be the better swap
Old 02-28-2005, 12:20 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: swap question
you can use the hydro tranny check out hasports.com for eveyrthing you need
Team Lonely Drivers
Old 02-28-2005, 10:09 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Re: swap question
For the coilovers the will work fine. All of those intercange between 1988-2000 civic and 1990-2001 integras. The hasport makes the kit for it. It basically is a bracket that goes where the stock tranny mount is. It makes the release lever be operated by the cable. And with hasport mounts it basically gets rid of the tranny support mount and just keeps 3 mounts(rear, right side, top tranny)
Old 03-01-2005, 07:36 AM
thanks for the info
