305 Performance
The first thing is exhaust..it is the most restrictive part of the engine's breathing. A larger throttlebody on a 305 is wasting money. The factory stock throttle body will supply more air than the 305 can use. Larger injectors won't do you any good..they will supply too much fuel. The prom chip is programmed for a set size of injectors, change them to larger/smaller and the computer is no longer supplying the correct amount of fuel. A set of Vortec heads will also require a special intake manifold, and for TPI there is just 1 source and it costs $400. You are better off porting a set of non swirl 305 heads. Pullies....snake oil, they can cause more trouble than they are worth. Cam....well, not yet. Before you begin trying to get more out of your little 305, get a cheap laptop, free scanning software http://www.moates.net/index.php?cPath=33 , A prom burner and prom adaptor http://www.moates.net/index.php?cPath=25 and a .bin editor. Learn about prom burning, get to know what is what on a prom chip and how to go about making changes and knowing what the changes do and affect. Try here for a good place to start http://www.eecis.udel.edu/~davis/z28/ Then it is time to think about more extensive mods like high flow intakes, cams, 1.6 rockers and the like. No "custom" burned prom you buy will ever be 100% correct, only someone that has the car at their disposal can hope to get the tune right. |
Re: 305 Performance
Re: 305 Performance
primary shortcoming of the 305 block is the size of the bore. it shrouds the valves and restricts breathing. If you are building a low rpm engine then it will still work just fine, but anything looking to make decent upper rpm power should be made with a 350. aside from that all the same rules apply. make it easier to breath, fight friction, poor combustion, and thermal power losses, and you will make more power.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
305 Performance
Re: 305 Performance
it wasn't deleted, it was separeted from this one, this thread isn't for feedback.
To be more specific, the thread is meant for tips on 305 performance, your post pretty much said all the suggestions that Damone said are useless, which they aren't. The last part of your post with the ecm programming links are all you should've put.
Breathing
Whenever you are altering the breathing capability of the engine you MUST consider both intake and exhaust. And when considering intake you must consider the size of the lungs. The lung capacity is vital to getting performance out of your setup. You simply cannot pump whatever you feel like into something that can only hold so much.
Remember there is too lean and too rich, but there is also flow and cc size. trying to flow 8000cfm into 6000cfm intake is futile and trying to combust 70ccs in a 60 cc is just as futile. Know what you're working with and then bring that flow capacity to its peak. |
Re: Re: 305 Performance
