Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-28-2005, 03:48 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
no Spark no tach
i have a 91 rx 7 im having magor issues with. for some reason im not getting any spark im getting fuel any sugections?
Old 02-28-2005, 06:13 AM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: no Spark no tach
lol
Old 02-28-2005, 07:03 AM
thanks alot for the laugh. i just got fuel to work today now spark, anyone that can help please! and if your realy an expert please give me a call 702-273-9300 thanks a lot!
Old 02-28-2005, 12:15 PM
D3rELiC's Avatar
check the crank angle sensor
Old 02-28-2005, 12:38 PM
what is their to check on it and what if im not getting any power to the crank angle sensor harnes and the coil pack's harness?
Old 02-28-2005, 12:53 PM
D3rELiC's Avatar
Re: Re: no Spark no tach
check the fucking crank angle sensor, LIKE I JUST TOLD YOU
Old 02-28-2005, 01:07 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
he can be a dick, just get used to it
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 03-01-2005, 01:35 AM
what should i fucking check on the fucking crank angle sensor!?
Old 03-01-2005, 02:13 AM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
got damm got back after a couple of day, and everybody got all violent!!
check plugs, coils, crank angle sensor, make sure everyting is pluged .
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
Old 03-01-2005, 05:56 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
No tach is generally a sign of the trailing coils going bad. Can you verify spark on the leading coils with a timing light?
1988 10th AE Edition TII
More mods then you have.
Old 03-01-2005, 10:12 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
^ i was just going to say that.
RX-7 TII
Old 03-01-2005, 12:45 PM
Soyo's Avatar
replace your coils and hope it fixes the problem
Old 03-01-2005, 05:45 PM
no spark at all
Old 03-02-2005, 02:37 AM
ok today i got one of the coil packs to get spark the one closest to the firewall the one by the batery is getting 7.5 volts on the main connector but is not getting any power on the coil itself. the 2 wires that come of the back of the coil that go to the igniters isnt getting any voltage durring cranking. any sugections on how to repair diognose these?
Old 03-02-2005, 02:49 AM
by the way its the ignition coil leading. that im getting 7.5 volts at main harnes and no volage on those 2 wires that are under the cap on the coil.
