Old 02-28-2005, 02:13 AM
kdrm kdrm is offline
Designing Atlas 12 enclosure need help
I purchased an atlas 12 and want to get the best SQ possible out of the sub. I need help and suggestions on box design. The specs say that it should be sealed and enclosed anywhere between .6-2.0 cubic feet. What would you recommend for maximum performance. Also does regular insulation work for the recommended poly fill in the box. I'm going to run the sub at the 33qts rating whatever that means, I'm just following the wiring diagram. I'm a carpenter by trade, but have little to no knowledge on subs, and tuning the box for them. Please help. I can build the box competantly, just need tips on making it right. Also I'll be running 300-400W rms to it. Thanks!
Old 02-28-2005, 01:50 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Designing Atlas 12 enclosure need help
Since your running it at the .33 Qts, then you have it setup for a small enclosure! So, i'd go with around .8 cubes NET to 1 cube NET at most.
Hit me up on aim: ngbd13
if you need help!
nG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 02-28-2005, 05:41 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
I'd do a cube after displ. but you can email Chad at ascendant and ask him he will be able to tell you best.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
