Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-28-2005, 12:32 AM
Butcher52 Butcher52 is offline
Send a message via AIM to Butcher52 Send a message via Yahoo to Butcher52
Question No 4X4 Engaging....
Here is my problem: I have a 93 explorer auto. tranny. It will not engage into 4 wheel drive. When I push the button I hear the idle drop down and a click noise towards the back of the vehicle. Any suggestions would be very appreciated.
Thank You,
butcher52
Old 03-01-2005, 09:14 AM
Gravesubject's Avatar
Gravesubject Gravesubject is offline
You're having the problem that many of us with Gen 1 explorers have: the OTF 4x4 system was, ahem, not robust. The click that you're hearing in the back is the 4x4 control module, behind the panel where the jack is stored. The problem is either that that module is shot, or the shift motor on the transfer case has seized up. In either case, a search of this forum will turn up lots of information.
Good luck... I still haven't fixed mine.
Old 03-12-2005, 08:18 PM
foresturyman foresturyman is offline
Re: No 4X4 Engaging....
Hello i have a 1994 Ford Explorer Xlt
i replaced my motor on the transfer case with brand new one
i can not get the truck to engage in to four wheel drive
all i get is the click click form the controll module
i am geting power at the fuse box
to every fuse
and have re check all connections
can any one help me thanks
Old 05-23-2005, 06:10 AM
skatemore skatemore is offline
This is a very common problem with ford explorers expecially with any locking hubs. If your relay is engaging that is a good sign. The first thing you need to do is get the vehicle off of the ground, so that you can put the truck in 4x4 to see if your front drive shafts turn. If they do not turn disregard this post. My guess is that the vehicle will go into low gear but the hubs do not lock. the most common reason for this is too much grease! some people grease these hubs like wheel bearings this is wrong. If the hubs have too much grease in them they will not engage. You may have to take the hubs apart and clean out all of the grease do not add wheel bearing grease use ATF(automatic transmission fluid). I had the same problem with mine. After cleaning the grease from the hubs the 4x4 works great. Hope I could help.
