Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-27-2005, 10:01 PM
ssenay72 ssenay72 is offline
Tie rod Grease fittings?
I bought trw tie rod ends, but theres no grease fittings on them? Whats up with that?
Old 02-28-2005, 08:10 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Tie rod Grease fittings?
They should come in a lttle bag with the tie rod ends. Just screw them in.
Old 02-28-2005, 10:54 AM
nope, no threaded hole to screw them in and no fittings they are sealed tight.
Old 02-28-2005, 11:00 AM
smonaldo smonaldo is offline
Return Them and get moog tie rod ends.
Old 02-28-2005, 11:10 AM
But Why Do They Do That? These Werent Cheap Either. The Guy At The Store Said The Better Ones Usually Dont Because They Dont Need To Be Greased Like The Cheap Ones?
Old 02-28-2005, 11:17 AM
blazee's Avatar
Problem?
you got the ones that are "greased for life" they are sealed and you don't have to worry about keeping them greased. But the ones that you grease yourself will last a lot longer as long as you maintain them.
It is judgement call.... do you want to grease them regularly? or do you want to change them more often? It's up to you. Personally I don't like changing them and having to pay for an alignment more than I have too, so I buy the ones with grease fittings.
Old 02-28-2005, 11:19 AM
I couldn't tell you that. All I know is that in 70000 miles I have gone through 3 sets of tie rod ends on my 2000. I had to pay for the last set because I was out of warranty. But I can bet that the "lubed for life" models don't last long either. I understand that the moogs have a lifetime warranty, and the grease fitting. On another note
tell me, are they difficult to replace, and do I need any special tools for either removal or replacement? I am mechanically capable, and the fact that I am going through these things like oil changes makes me inclined to add the tools to my tool box and do it my self.
blazee's Avatar
Problem?
Please Stop Capitalizing The First Letter Of Every Word...It Hurts My Head.
Old 02-28-2005, 11:29 AM
blazee's Avatar
Problem?
smonaldo,
Did you ever grease your old ones?
It's not that bad of a job. Buy new sleeves too. it saves the trouble of having wrestle with old ones. measure the distance between the old ends and make the new ones the same, that will get your alignment fairly close.
You need a "pickle fork" .....that is the common name for a tie-rod end seperator and you will have to align the front end when finished.
Old 02-28-2005, 11:38 AM
Unfortunately, I left the maintenance of the old ones to the lube monkeys, and I am certain they did not grase dilligently. I am familiar with the pickle fork, Sears sells a complete set, reasonable. From what I remember, I could simply count the rotations when I unscrew the old end out of the sleeve, but I guess what you are recommending is a complete replacement of inner and outer ends. When you install the new ones, does the fastening nut press the post into place?
Old 02-28-2005, 11:53 AM
blazee's Avatar
Problem?
I don't know how much sears charges but I paid $10 for mine at Advance Auto.
Yes when you install the new one just tighten the nut to the recommended torqued and it will be properly pressed into place. If neccessary you can tighten just a little more if you need to, to get the pin in.
Old 02-28-2005, 09:32 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Don't buy TRW, buy Moog replacement parts.
Lifetime warranty and top quality.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-03-2005, 07:48 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
TRW is also top quality and they come with lifetime replacement...
Old 03-03-2005, 09:36 AM
but no grease fittings.....
Old 03-03-2005, 03:30 PM
BlazerLT's Avatar
AF -Advisor
Moog is the way to go. Excellent quality, greasable and they are the #1 name in the replacement suspensio parts industry for a reason.
They make awesome parts.
