Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-22-2002, 09:51 AM
Boner Boner is offline
Unhappy Ball joint problem
I have a 93 civic DX Hatchback. I just replaced the driver side drive axle. I'm putting it back to gether and I'm having problems with the ball joint that connects the outer end of the front loer control arm to the steering knuckle. This had a crown nut on it and I needed a pitman puller to get it off. Now, when I try to put the crown nut back on the bolt coming down out of the ball joint just spins. I appears that I need to somehow compress the ball joint to stop the spinning. I guess. Do any of you suspension knowledged guys know how I can get this nut back on and /or how do I compress this MF. I'm so close to done and the f'n weather is like 15 degrees out so I need the quickest solution possible.
Old 03-26-2002, 11:33 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
I just stuck some pliers in between the pitman arm and the top to the ball joint and had my friend hold it REALLY tight while i tightened the bolt from the bottom in. After you get it on MAKE SURE you put in the cotter pin or the bolt on the bottom could come loose. Im sure there is an easier way to do it but i never knew how.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-27-2002, 09:05 AM
Thanks Man, I finally got it on after it was nice out. I bought a 3" universal clamp and got it in the right spot to hold it in place. Once I cranked it down I had no problems tightening it down.
Thanks for you reply!
Ball joint installlation for 2001 Taurus SEL Doug Tatham Taurus | Taurus Wagon 10 09-28-2020 07:37 AM
ball joint or tie-rod end? thinmint Dakota 1 03-07-2010 10:39 PM
Ball Joint question - confused... caffeineaholic Caprice 8 12-19-2009 06:17 PM
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
Ball Joint Problems???? 99fordranger Ranger | Courier 1 02-06-2005 08:56 AM
