Old 02-27-2005, 08:22 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Sub Placement
Well I am in the process of making a fiberglass sub box. I was thinking about having one sub in normal and one with the mag. sticking out. Will this effect the sound any?
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 02-27-2005, 10:16 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Sub Placement
mount them both the same way unless they box is either sealed off between the two or in two seperate boxes, the subs hit at the same time, meaning one will be going up and the other going down (because they are inverted) nutralizing sound and pressure blah blah blah it wont be good unless it is in seperate boxes
Old 02-27-2005, 10:25 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: Sub Placement
i heard it doesnt matter what way they facing
1991 Honda Civic DX Sedan
Old 02-27-2005, 10:31 PM
Re: Re: Sub Placement
Me two. See here is the problem. This is in a limited space. One sub can go down becuse the box is deep in that part, but can't stick up because it will hit my cover. The other the box is too shallow for my sub but it will fit inverted.
Old 02-27-2005, 10:33 PM
Re: Sub Placement
then give it a try, it wont hurt anything for sure
Old 02-28-2005, 03:11 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: Sub Placement
As long as the subs have different air chambers (separated), they should be okay. Otherwise it would be like you and a friend take a straw and both try to blow into it, at opposite ends, at the same time. It's not going to work very well.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 02-28-2005, 03:27 PM
thats what i said, your analagy is much better though
Old 02-28-2005, 03:35 PM
Figori's Avatar
Re: Re: Re: Sub Placement
Thanks.
Old 02-28-2005, 05:18 PM
89si's Avatar
89si 89si is offline
Re: Sub Placement
would sealed or ported be better in our hatches? and without dynamat or something similar, does everything rattle like hell? im gonna be putting in a 12" alpine R within the next month if things work out for me (as in no more fucking parking tickets for $50)
any experiences you're willing to share would be awesome to hear, cuz im just worried that it'll sound like shit inside, and rattle everything outside. with just my alpine R speakers i have some bad rattling, including my passenger outide mirror, rear license plate, driver side 'door bumper' and lots of things inside obviously.
sorry to hijack, but this seemed like a decent place to ask this stuff.
89si-
78000kms on original engine.
sub is in.. lights are just about done..
Old 02-28-2005, 05:19 PM
Re: Sub Placement
in small confined spaces, ie anything smalller then an escilade, sealed alwase alwase alwase
Old 02-28-2005, 05:26 PM
89si's Avatar
Re: Sub Placement
specific explanation? something to do with air space and whatnot? thanks for the response, but im kinda lookin for something more, thx.
89si-
Old 02-28-2005, 05:34 PM
Re: Sub Placement
ok ill give it a try, ported boxes, when done correctly sound very nice, however are verry large and verry expenceive, sealed boxes, in small confined spaces ie vehicals, sound just as good as a ported box, if not better because there is no air ruffle, a sealed box also takes less volume to produce the same sound, so a sealed box is smaller, and more efficent costly and size waise for your car
Old 02-28-2005, 08:38 PM
Totally true which is why I am making a fiberglass box. I have a ported box that takes my entire rear hatch up plus my cargo cover won't close. It sounds good but it way to large. My box cost $175 (well for normal peeps it does )
Anyways about the sectioned part. I knew that much, I was just wondering if they produced the same sound and all. I think I have figured out a way to get them both in right hopefully. We'll see, I will post up pics when I get it done.
Old 02-28-2005, 09:59 PM
Re: Sub Placement
as far as which way you mount them, no it doesnt matter, i had a set of mtx 6000 duel vc inverted in my fs chevy so that huge chrome magnet was sticking out for the world to see (hey ill give you one guess as to which one of my vehicals was broken into and had a system stolen out of it) and it sounded no different then mounted magnet down, if you can seal the two chambers off go right a head and do it, i think it will look awsome and should produce excellent sound
Old 02-28-2005, 10:50 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
but wouldnt it be more like one person sucking thru the straw while the other blows? so the one sucking will extend more, meaning the one facing out would extend more kinda
