Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-27-2005, 06:49 PM
dave325 dave325 is offline
Power Steering stopped working without warning
2001 ext cab. w/ 4.8 and 32,000 miles.
The power steering has worked great. Without any warning it just stopped working. The fluid level is fine. Fluid is clean. No leaks. I don't have a clue what's wrong.
Old 02-28-2005, 04:55 PM
2000CAYukon 2000CAYukon is offline
Re: Power Steering stopped working without warning
I believe the pulley is pressed onto the pump. The pulley is probably slipping on the pump shaft.
Pretty sure you are looking at a new pump but maybe one of the GM Techs can reply with what needs to be done.
//2000CAYukon
Old 02-28-2005, 07:59 PM
Thanks for your response. I checked it and the pump shaft is turning.
Someone said the power steering lines might be plugged.
How do you clear those? With an air compressor??
Any other ideas??
Old 03-01-2005, 04:02 PM
craigix craigix is offline
I only have a 1999 classic shape with the 7.4 but I just rebuilt my power steering and it works fine now, I just took it to pieces, emptied the old dirty fluid, cleaned all the parts up, replaced 2 hoses and put it back together.
Then I put a little fluid in and had my sister start the engine so i could watch the pump and make sure it sucked it away and kept adding until the level was back to normal. Works fine now. Didn't take long to do either, I don't know if the layout on the new shape is the same though.
-Craig
Old 03-04-2005, 07:11 PM
Thanks Craig,
I'll try that tomorrow morning.
Old 03-05-2005, 09:01 PM
Well, it was the power steering pump. Fluid was brown. It only has 32,000 miles.
