Old 02-27-2005, 06:36 PM
sleeper2 sleeper2 is offline
Send a message via ICQ to sleeper2 Send a message via AIM to sleeper2 Send a message via Yahoo to sleeper2
same question....want different correct answer
ok here it is
92 grand caravan 3.3l
fuel pump kicks on when key is turned...
when i turn the engine over there is no fuel going into the cylinder nor is there any fire to the cylinder
here is what i have changed so far
auto shutdown relay...
coil....
ignition control module
and soon that stupid box on the firewal whatever that is for
now what i dont want to hear is check the crankshaft position sensor cause everyone on here is havinf problems but is getting nowhere with the CPS
Old 02-28-2005, 06:32 PM
yogi_123rd yogi_123rd is offline
Re: same question....want different correct answer
If you are having problems locating the sensors, you can go to the site "autozone.com", specify your vehicle and engine size. On the left screen is "component locations" and look for the sensor in there. The output comes out like...
On your 1992 DODGE TRUCK CARAVAN 2WD, the CRANKSHAFT POSITION SENSOR is:
UNDER HOOD, DRIVER SIDE, UPPER ENGINE AREA, MOUNTED ON END OF ENGINE BLOCK
On your 1992 DODGE TRUCK CARAVAN 2WD, the CAMSHAFT POSITION SENSOR is:
UNDER HOOD, PASSENGER SIDE, LOWER ENGINE AREA, BELOW WATER PUMP, ABOVE CRANKSHAFT PULLEY, MOUNTED ON TIMING COVER.
Old 02-28-2005, 06:42 PM
1thunder 1thunder is offline
did you change these sensors or are you just pee'd off cause you cant find them?
