Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 02-27-2005, 06:12 PM
stevengad stevengad is offline
Question fuel door
Hi, i just bought a 95 talon tsi awd, nice car! question is my fuel door will not open unless someone holds the latch up inside while another opens the door outside. i have bent the latch on the door so i can fill up by myself, but just want ths to be a temp fix. can u guys tell me if your door has a spring in it so that when u pull the latch the door opens past the latch. thx all
Old 02-27-2005, 06:34 PM
SmicAA72
Guest
Posts: n/a
Re: fuel door
I have this same problem with my trunk, I have to make several trips from my latch opener I guess you would call it to the trunk, pulling up to see if it popped all the way.
Old 02-28-2005, 08:02 PM
shadow eclipse shadow eclipse is offline
Send a message via AIM to shadow eclipse
Re: fuel door
I would check that cable that operates the release for the door, prolly got loose, just unscrew the little plate that goes over the lever and inspect it. then i would check out the one hooked to the fuel door latch. Hope this helps, peace
Old 02-28-2005, 08:34 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: fuel door
the problem is the spring that pops the door out. try wd40'ing the hinges and mechanisisms at the fuel door. im not sure how its setup on a 2g but if you can pull it open while you hold the release then the problem isnt the release cable.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-01-2005, 06:28 PM
Re: fuel door
thought that there was a spring on the door! problem is its gone! is not clear though on where it connects to the door and the body... anyone? thx
Old 03-06-2005, 09:16 AM
Re: fuel door
C,mon Guys....know U Have The Answer
95 TALON TSI AUTO
