Old 02-27-2005, 04:13 PM
Tey_Marzetti Tey_Marzetti is offline
Send a message via MSN to Tey_Marzetti
Need help
92 Cavalier RS v-6. Runs fine, but stalls after warm-up. Stalls in gear and in neutral.
Not sure where to start. Bad gas? Fuel filter?
Old 02-27-2005, 06:43 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Need help
Could be vacuum leak, bad MAF, ignition problem or problem in your fuel system. You need to check the following. Good Luck
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-27-2005, 06:47 PM
John Thanks
whats an MAF? Oh and where is the motor for the convertible?
Old 02-27-2005, 07:05 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Need help
My bad, I just looked up the 92 3.1 and they used a MAP (for speed density fuel injection) and I thought you had Mass air flow system hense MAF. Anyway a bad map sensor could be telling your car that you have more or less air than you actually have in the intake which would cause the PCM to add the incorrect amount of fuel. Which would cause your car to flood and stall or starve of fuel and stall.
John
Old 02-28-2005, 10:16 AM
Cavalier
Thanks John I will check it out.
