Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-27-2005, 04:02 PM
JDM00CivicEX JDM00CivicEX is offline
help me guys.
i just dropped a b20vtec in my 00 civic ex last saturday. the swap consists of a 1990 B16a head, a 1996 b20b block and a 91 B16 tranny. The head has a 3 angle valve job, everything else is stock. i am running an obd2 setup with the sohc injectors and a fuel pressure regulator. the timing is right all the plugs are plugged in correctly. it only wants to stay idle at around 1200 rpms. i have new distributor, platinum +4 sohc spark plugs that came off my sohc civic ex and new spark plug wires. we have tried to mess around with a idle screw and if u bring below 1200 rpms, it just shuts its self off. the fuel guage is reading 42psi and i know the car is running rich becuase it back fires big time. but alot of the time it also back fires out of the intake which i know is not good and you can also hear it leave some of the exhaust valves open while the intake valves are open. i have aem tru time cam gears which are set to 0 degrees, and i dunno if the cams are actually stock or after market. i was wondering if i can get some help with this major problem. thanx
Old 02-27-2005, 04:23 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: help me guys.
my advice is to switch to obd1 and run hondata. without tuning its not going to run at its optimum performance.
Team Lonely Drivers
Old 02-27-2005, 04:26 PM
Re: Re: help me guys.
but it should atleast run straight stock, instead of switching over, cuz i know people that have bought cars with swaps running obd2 setup and it runs prefectly fine.
Old 02-27-2005, 04:28 PM
Re: help me guys.
could be your fpr. have you tried running the motor with the stock fpr ?
Team Lonely Drivers
Old 02-27-2005, 04:35 PM
nope but ill try that, thanx for the advice.
Old 02-27-2005, 08:25 PM
tried with the stock regulator and it does the same thing, re adjusted the valves. still back fires from intake and exhaust. does not want to idle under 1200 rpms. sounds like its running too rich. still getting 2 codes that say miss fire. and also change the spark plugs and put brand new plugs in and made sure they were gapped right.
Old 02-27-2005, 08:43 PM
Re: help me guys.
what ecu are you running ? if its running really rich, turn down the fp alittle then try drop the idle
Team Lonely Drivers
Old 02-27-2005, 09:40 PM
ok ill try that, do you know wut the average Psi the fuel should be at cuz mine is at 42psi, and ive heard 40psi is good. and i am running an obd2 p2t civic si ecu.
Old 02-27-2005, 10:26 PM
Re: help me guys.
38psi at idle i think
Team Lonely Drivers
