Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-27-2005, 02:56 PM
KaMaKaZiPyRo KaMaKaZiPyRo is offline
Send a message via AIM to KaMaKaZiPyRo
High HP Maintenance(sp)
I juss wanna get an idea of what all I would need to change once a year or even once a month if I had a turbo charged car pushing around 400hp daily driven.
Currently trying to piece together a Turbo CrVtec bubble hatch, expecting sumthin like 500hp?!?!?!
Old 02-27-2005, 02:59 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: High HP Maintenance(sp)
you need to change spark plugs every oil change. unless yoru running iridiums then every other oil change.
Team Lonely Drivers
Old 02-27-2005, 08:02 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
You should change your daily driver...
get a beater car if your gonna be pushing "400hp" on your daily.
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-28-2005, 08:14 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: Re: High HP Maintenance(sp)
Man i thought you were supposed to change them every 500 miles with forced induction. Boy, thanks for the good info.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 03-01-2005, 01:53 PM
boosted331 boosted331 is offline
rofl, something larger than a 16 year old's budget.
Old 03-01-2005, 02:02 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Yea that too.
