Old 02-27-2005, 02:48 PM
mitsu_3000_gt_vr4 mitsu_3000_gt_vr4 is offline
problems
im guessing its the tranny but i have not driven my car for a while since when it drives it jerks making a loud thump and from the outside it comes from the front and just move it a couple inches trying to figure out what it was and the tires will just pause and go again. someone help me but i think it is the tranny since the synchronizers im guessing were going out as well plus what all happens exactly when they go out my gears would grind or somethin in first second and third and i was told it was the synchros
Old 02-27-2005, 03:10 PM
Igovert500's Avatar
blue + red light magnet
Re: problems
If you try restructuring that in a somewhat coherant structure, with punctuation...I'm sure we could help.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-27-2005, 03:39 PM
Re: problems
sorry about that I was in a hurry. Ok my car when you drive it just a few inches it jerks and my tires basically just stop and go it is coming from the front which hopefully means that its not the rear differential but i could be wrong. Im basically thinking its the tranny seeming how the synchros were going out already but i was also told that the synchros werent going out and it could be the clutch. So basically i need to know what main things happen with the synchros and why my car jerks like it does thanks for the help
Old 02-27-2005, 04:45 PM
Igovert500's Avatar
Re: problems
Well synchros cause grinding during shifts...so I don't think it is that.
So you are saying that when start the car, put it in first and start moving forward that the car jerks? Does it jerk violently? Have you driven it more than a few inches? Are you getting any Check Engine lights or flashing lights on your dash?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-27-2005, 06:14 PM
pitbullgst pitbullgst is offline
Re: problems
it jerks pretty rough and it started and the only driving its done that was more than just a little bit to see it happen was i drove it home cause i couldnt leave it at my friends house. and that is why i was told that the synchros were going out it was grinding it the first 3 gears
Old 03-01-2005, 01:22 PM
Re: problems
the pitbulwas me i was on a friends computer not thinking so help me
Old 03-01-2005, 02:28 PM
2old 2old is offline
Re: problems
My car kind of did that when the exhaust gasket between the header and the downpipe develeped a leak but only when I really leaned on the gas petal at low RPM ( <2000 ). After I fixed the leak the problem went away (Strange thing is the check engine light never came on).
If this was combined with bad motor mounts this would probably make a thump with the jerk. So the problem could be with a O2 or MAS sensor and some weird reading that the ECU can't make sense of... Just a thought.
Old 03-01-2005, 07:25 PM
Igovert500's Avatar
Re: problems
Still havn't said if you have any Check Engine lights.
Also did you do anything to the car recently, any work or anything on it?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
