Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 02-27-2005, 02:25 PM
GAGS6996 GAGS6996 is offline
Angry 3800 Engine Oil Pressure Problems
HAS ANYBODY HAD OIL PRESSURE PROBLEMS ON THE 3800 ENGINE?
I HAVE AN 1994 EIGHTY EIGHT LSS.....WHEN I START THE ENGINE IT HAS A LITTLE TICKING NOISE.....AND WHEN I TAKE THE CAP OFF THE VALVES LOOK DRY.....ANY SUGGESTIONS
JOHN
[email protected]
Old 02-27-2005, 02:39 PM
Ofnarcr Ofnarcr is offline
I donno but stop with the caps.
Old 02-27-2005, 04:03 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
Re: 3800 Engine Oil Pressure Problems
It could be a bad oil pump, or clogged pipe somewhere, clogged air hose, or oil hose
Old 03-05-2005, 09:21 PM
chevelleman chevelleman is offline
Send a message via AIM to chevelleman Send a message via MSN to chevelleman
dont jump to conclusions check your oil pressure with a mechanical guage first before you try and tear anything a part you can remove the oil sending unit usually located on the oil filter adapter housing and screw in the mechanical guage and check the pressure then you will know if its any oil pump or something else if anything
