Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-27-2005, 12:44 PM
94talontsi89's Avatar
94talontsi89 94talontsi89 is offline
Send a message via AIM to 94talontsi89
cigarette lighter problem
ok I was gonna go put my radar detector in my car. then when I hooked it up it wouldn't turn on. Then I went to see if it worked in my mom's car and it worked in my mom's car. I checked the fuse for the cigarette lighter in my car and it wasn't burned out. so I turned on my car and turned on the radar detector and still wouldn't work and ideas what the problem would be?
http://members.cardomain.com/98talonesi89
Eagle
Talon Esi
1998
5-speed
dohc 2.0L 16 valve
all stock (for now intil summer comes)
Old 02-27-2005, 03:11 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: cigarette lighter problem
check that the wires are connected to the cig plug and make sure its clean. try twisting the plug side to side too sometimes it only works at a certain angle
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-27-2005, 04:24 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
take the drivers side panel off and check the wires and plugs. most likely the plugs arent on
Old 02-28-2005, 06:00 AM
ok ill check today and see if that's the problem
Eagle
Talon Esi
1998
5-speed
dohc 2.0L 16 valve
Old 02-28-2005, 07:26 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
yeah I would definatly check that. I thought my cig lighter was broke for a month till I noticed one of the plugs slipped off when I was installing my clarion. Also I have noticed as well sometimes to run accesories (liek my cell charger) you have to twist it real slow till it pops on. Good luck! peace
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 03-04-2005, 01:18 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
the inside walls of the ligther part attached to the car might be corroded and not forming a good connection. also check the fuse and make sure the wires on the back are connected CORRECTLY, otherwise you could fuck somethin up.
95 Talon TSI AWD
97 Eclipse GST
Old 03-09-2005, 06:35 AM
hey it's working now I had to put it in a certain way and have it not forced down but pushed down.
Eagle
Talon Esi
1998
5-speed
dohc 2.0L 16 valve
