Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 02-27-2005, 12:40 PM
SmicAA72
Guest
Posts: n/a
Spoiler Hole Lineup
Does anyone know if I remove the 3 piece GS spoiler, and put on the GSX or GST Turbo Spoiler, will any of the holes line up, I know I will have to fill in alot of holes, but will I have to drill new ones for the new spoiler?
Old 02-28-2005, 05:25 PM
SmicAA72
Guest
Posts: n/a
Re: Spoiler Hole Lineup
Anyone?
Old 03-01-2005, 01:11 PM
SmicAA72
Guest
Posts: n/a
Cmon you guys know everything, you gotta know this
Old 03-02-2005, 08:01 PM
SmicAA72
Guest
Posts: n/a
PLEASE! I NEED HELP IM GOING INSANE AHHHH! Seriously though, no one knows?
Old 03-02-2005, 10:20 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
no!
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 03-03-2005, 01:39 PM
SmicAA72
Guest
Posts: n/a
Jesus, whats with the attitude its not like im being an ass for asking a question, thats what this is for, or so i thought.
Old 03-03-2005, 04:11 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Someone answers your question with a 'no' and you get all pissy over it?!?! You keep posting in your thread over and over again like a jackass, and then throw a fit when someone gets pissed as you for doing that? WTF!!! Calm down dude.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-04-2005, 06:20 AM
SmicAA72
Guest
Posts: n/a
I thought it was a relatively easy answer, yes or no, and I didnt understand why no one was answering. All I needed was a "no", not a "no!" because he finally got fed up enough to give the effort to answer my ?. Im not the one that isnt calm, his post is the one that ends with an exclamation point.
Old 03-04-2005, 07:19 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You could have searched and found the answer yourself. We only see this questions once or twice a week.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-04-2005, 02:47 PM
david-b's Avatar
Dave is THAT guy
LMAO... "his post ended with an exclamation point..." Thats too funny. Let's see how many lines that end that can have a exclamation point:
Happy Birthday! <- End post
Good Luck! <- End post
Bye! <- End post
Thanks! <- End post
Damn, I can go at this all day long. Anyone else?
Thanks!
75 Monte Carlo
Old 03-06-2005, 10:47 AM
yellowspyder's Avatar
yellowspyder yellowspyder is offline
Send a message via AIM to yellowspyder Send a message via MSN to yellowspyder
The three piece is simple to remove. Open your trunk and theres 2 screws on the inside edge. remove them. that will take the platic off youll be left with a plate there with 3 more screws in it. remove them and piece one is off. do the same on the otherside as well. then I belive the center piece you have the removethem from the insde of the hatch. don't know if youll have to remove paneling trim or not. I have a spyder and did not have to. I think there were a total of 12 holes to be filled after it was off. The Gst spoiler will not line up with these holes as far as I know. it isnt as wide and will not reach the outer most holes from the 3 piece. don't know 100% though as I never tried to re install the turbo spoiler.
Old 03-06-2005, 12:01 PM
SmicAA72
Guest
Posts: n/a
Thank you very much yellow spyder.
