Old 02-27-2005, 11:05 AM
mus5.0tang mus5.0tang is offline
Send a message via AIM to mus5.0tang
Question no heat and antifreeze leak
hey guys, my heat blows cold air and i have recently noticed antifreeze leaking from the drivers side rear of the engine. at first i thought it might be a heater core but doesnt that make the defrost worse?? my defrost works fine its just cold air.
Old 02-27-2005, 01:35 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Re: no heat and antifreeze leak
its got to be the heater core or the hoses leading to it.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 02-27-2005, 01:42 PM
Re: Re: no heat and antifreeze leak
thats what i was thinking. do you know any way i can check to make sure it is that before i go taking the whole damn dash apart to replace it.
Old 02-27-2005, 02:16 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Re: Re: no heat and antifreeze leak
Your de-frost blows hot air?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 02-27-2005, 02:21 PM
no it blows cold too.. the heat gets warm after a while though.. not hot but warm
Old 02-27-2005, 02:26 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
does a foul smell come out of the vents? also check under your passenger side floor mat for antifreeze, thats where it would drip from your heater core to.
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 02-27-2005, 02:27 PM
that is why i am in doubt for the heater core.. there are no sweet odors from the vents and the passenger side floor is dry.
Old 02-27-2005, 02:49 PM
SkylineUSA's Avatar
If your only getting warm air, I would bet the farm that heater core is plugged, or partially plugged. I did mine, its not that big of a deal. Go on get your hands dirty, you know you want to
You can run a garden hose to it, and see if there is any crap in it.
The leak is coming from the firewall, or the engine block?
Old 02-27-2005, 02:50 PM
do you know how much heater cores go for on a 88 mustang.
Old 02-27-2005, 02:53 PM
SkylineUSA's Avatar
Check on line, I would figure about $30.
Old 02-27-2005, 11:55 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Well having no heat can just mean that your low on coolant, hence the leak. That alone wont direct you to a bad part. Where is the coolant coming from, the motor, hoses, firewall, etc?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-28-2005, 05:48 AM
it looks like the coolant is dripping down to the drivers side rear of the engine bay. i personally have never seen a coolant leak there, hence why i ask what it could be.
Old 02-28-2005, 05:49 AM
but i do keep adding fluid so there should be enough in there all the time to keep the heat working
Old 02-28-2005, 09:55 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Good point, low or no coolant will result in poor heating. Heater cores are pretty cheap, about under $20 bucks in store, if that's the case.
First thing you really need to do is find where the leak is coming from. Have the sytem pressure tested to pinpoint the exact leak.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
