Old 02-27-2005, 10:02 AM
Eclipsewhipping Eclipsewhipping is offline
Check engine light egr valve
My check engine light went on the other day and i took my car to autozone to get a diagnostic reading, the reading only found one code and it was for a egr system failure, how much would it cost to fix and is it a time consuming projecT?
Old 02-27-2005, 10:52 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Check engine light egr valve
Not time consuming. I had mine done because i didn't know what it was. that damn thing was like 200(if i remember correctly) dollars from the dealer. I dont know what kind of car you have and I dont know if gst/gsx's are different or have them.
....It has been a LONG time...I want to move to FL or Japan.....
Old 03-01-2005, 12:11 PM
loco69boyz loco69boyz is offline
You can get a egr block off!!
Old 03-01-2005, 12:22 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
im curious is that CEL makes the car run in a safty mode or anything?
Old 03-02-2005, 03:33 PM
Please Help , i got a problem
OK i got a 1996 eclipse spyder wit 60k miles on it, it has a EGR FLOW MALUNCTION.. does any body know what this could be? how much it will cost to get fixed? any body have problems simmilar to mine and what did they do? thanks for your help.
Old 03-02-2005, 03:55 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Please Help , i got a problem
bad egr valve, plugged hoses/tubing, bad sensor. anything related with recirculation of exhaust back into the intake.
95 Talon TSI AWD
97 Eclipse GST
Old 03-02-2005, 08:19 PM
o ok thanks,, how much do you think the worst case scenerio would cost to fix? do you have a price range?
Old 03-02-2005, 08:54 PM
what do u mean you can get the egr block off?
Old 03-02-2005, 08:58 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Chances are you could find a new EGR in the at the junkyard. That, or you could block it off entirely, however that won't fix your CEL problem.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 03-02-2005, 09:22 PM
if i removed the egr? would the car run any diffrent? i think id rather just get it fixed and pay the money..how much u think it would cost?
Old 03-02-2005, 09:29 PM
drewh4386's Avatar
well if you get it done at a dealership, the egr itself will be about 200 bucks (i have to find my receipt)
Old 03-02-2005, 09:51 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Merged because you made 2 threads that were the same. Don't do it again.
Old 03-03-2005, 04:22 AM
thefro thefro is offline
well the egr is there for emissions, plain an simple. it is made to opperate ate speeds between 30-70mph at light cruse speeds. it puts a inert gas back in to the cylinders to cool them down. when you run at steady high way speeds you dont need as much fuel to maintaine your speed. with less fuel the cylinder temp goes up and then you increase your nox emissions. it should be ran off manifold vac. to open and close the valve when you give it more throttle it closes and puts more fuel in to the cylinder thus having the same result. by taking it out you will run hotter at light cruse speeds. you might notice a little change in gas milage but it will not increae the hp of your car. by running hotter you do run the risk that if you get hot enough that you could melt pistons but i know many people that have no problems after taking it out.
Old 03-03-2005, 02:27 PM
anyone know where i can purchase a egr valve/parts?
Old 03-03-2005, 05:29 PM
napa, autozone, any auto parts store
95 Talon TSI AWD
97 Eclipse GST
