Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-27-2005, 10:00 AM
ALberto12 ALberto12 is offline
Exhaust smell from trunk to passenger area
Currently experiencing exhaust scent/odor strong from trunk to cabin section of 1992 camry. Looked at all moldings, found to be ok. took it to (2) different mechanics unable to solve. Air condition works great, Outside circulating vent is either in the close or open position still the same results. Muffler is in excellent conditions, no holes. please help.
Old 02-27-2005, 11:47 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Exhaust smell from trunk to passenger area
Check to see that your vent is actually moving when you change from "outside air" to "Recirculate". It may be stuck on "Recirculate".
Old 02-27-2005, 07:34 PM
Re: Re: Exhaust smell from trunk to passenger area
Thanks Brian, but already checked and found ok. Still smells exhaust.
Old 02-27-2005, 08:48 PM
Brian R.'s Avatar
Resident Chemist
Is your fan working correctly?
Old 02-27-2005, 09:30 PM
moonshine moonshine is offline
Under the rear seat, there is an access door or cover to the fuel pump and fuel level sending unit.This cover could be loose or the seal is bad. The rear seat can be removed easily by lifting the front of the rear seat up and pull out.
Old 02-28-2005, 06:45 PM
Hey Moonshine, this may be the best lead thus far. Will try it and foward the results, Tks much
Old 02-28-2005, 06:48 PM
Fan blowing like a charm. But will check to see if it's blowing strong enough. Tks much
