Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-27-2005, 09:39 AM
steffi21 steffi21 is offline
Rear wheel drive option-1994 -Where is it?
Hi,
We just bought a 1994 Grand Cherokee and can't figure out where the rear wheel drive option is or what it is? I understand that it can be used for optimal gas mileage and right now the jeep is getting 16 mpg...is that average mpg for this jeep?
Thanks for any information.
Old 02-27-2005, 04:26 PM
porscheguy9999's Avatar
porscheguy9999 porscheguy9999 is offline
Send a message via AIM to porscheguy9999
I cant help you until yuou tell me what engine you have, Inline 6 or V8. And what type of All Wheel Drive system do you have? My 95 GC has Quadra-Trac All Wheel Drive. Once I know, then I may be able to help you.
Currently:
1998 BMW 328is black/black coupe 5MT
Thanks to Nicecar!
Got a Facebook? Join the AF group!
http://hs.facebook.com/group.php?gid=2213949483&ref=mf
Old 02-27-2005, 05:18 PM
Re: Rear wheel drive option-1994 -Where is it?
Thank you for your prompt reply.
It is a V-8 engine and the all wheel drive shift is on the floor next to the regular gear shift box, which is also on the floor/console. Sorry I don't know the correct terminology.
Where would I find the identification for which type of 4-wheel drive system it is? Thanks again.
Old 02-27-2005, 06:47 PM
mikec041 mikec041 is offline
With shift lever it's either a command trac or a selec trac
both are in 2 w/d mode when lever is fully seated toward the dash board.
the 4 w/d light ( amber or green) on dash will be out. You may have the instructions on the drivers sun visor
Old 02-27-2005, 07:30 PM
JDPascal JDPascal is offline
The V8 models come with the Quadratrac and the I6 has the Selectrac unless someone has swapped transfer cases.
Quadratrac is the full time 4wd with 3 positions on the shifter. (4Hi N 4LO)
It should say Quatratrac on the trim around the shifter.
JD
