Old 02-27-2005, 08:53 AM
loveangel4ualways loveangel4ualways is offline
Unhappy 0verheating
i have a 1994 3.4L 6-cylinder camaro. I have replaced my fan motor and the waterpump and it still runs hot, does anyone have any ideal what it could be? thanks
Old 02-27-2005, 10:36 AM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: 0verheating
how about your thermostat....
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 02-27-2005, 10:25 PM
ct91rs ct91rs is offline
along with the thermostat, check the hoses. If they're old they may look ok, but they could be collapsing causing a restriction in flow...
Old 02-28-2005, 08:23 AM
Re: 0verheating
i'm gonna replace the thermostat and the hoses on tuesday, because i just got the car and i have no ideal what could be wrong with it, the only other thing it could be is the radiator or the sensor. thanks ya'll.
Old 02-28-2005, 08:48 AM
Re: 0verheating
does anyone know where the thermostat is located?
Old 02-28-2005, 09:28 AM
I'm not sure on a V6, but you can most likely trace the upper hose from the radiator to the intake. The upper hose should connect to the intake at the thermostat housing, remove the two bolts for the housing and you will find the thermostat...
Old 02-28-2005, 09:30 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 0verheating
Here is a pic of the cooling neck/thermostat assembly.
Just Remove the 2 screws on that housing(I know its hard to see in the pic but just look in that location on your vehicle and follow the cooling line to the neck), then lift off the housing and the thermostat is right in there. Good Luck.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-28-2005, 03:27 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: 0verheating
be sure you get that problem fixed an overheating engine is murder on your tranny if its an automatic. i had to drive a camaro home in reverse one time because i let mine overheat without fixing it a long time.
Old 03-01-2005, 01:08 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Maybe its your radiator, though I doubt it, but im just throwing it out there as a suggestion.
Old 03-01-2005, 09:11 AM
Re: Re: 0verheating
John
thank you for your help
Old 03-01-2005, 10:46 AM
Twitch1's Avatar
Twitch1 Twitch1 is offline
Re: 0verheating
Get the radiator rodded out! You got a rad that's 11 years old and if it ain't been douched out before it IS clogged with corrosion! I got a 2nd gen Z-28 with brass so I assume for sure your 94 is aluminium/plastic or aluminium or whatnot. When you drop it back in after clean out be sure to use Dexcool- the red-orange coolant. It's superior in aluminium rads.
1973 Z-28
1965 Nova
1950 Packard
1996 El Dorado Touring Coupe
There is no substitute for cubic inches
Old 03-01-2005, 10:51 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: 0verheating
good god get that car off i feel like im gonna have a seizure
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 03-01-2005, 12:34 PM
Re: 0verheating
okay i just fixed the thermostat and it ain't running hot no more, but when i went to start it up something popped, then the starter started spinning and hitting the fly wheel. does anyone know what is wrong with this pos?
please help
Old 03-01-2005, 06:57 PM
sounds like 2 things. 1 it could have been in a bind somehow and broke a bolt and isnt making good contact with the fly wheel, or 2 it was in a bind and just broke the wheel off the starter. the only way to be sure is to get onder it and check and see what happend.
