Old 02-27-2005, 07:14 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Aftermarket Air Intake
I've been looking to get started with modification, and an intake seems to be the first step to I/H/E. Better throttle response for a smaller amount of money. Was looking to buy one in the next couple of weeks.
First Question: Short-Ram or Cold-Air? Which is easier to install and is the lower temp from the cold-air really worth it?
Second Question: Which manufacturer? Is eBay fine? They have em for cheapo on ebay. Was wondering if there's any noticeable difference between that and another site, or do you get what you pay for? I heard the filter is what makes the difference.
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-27-2005, 07:28 AM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
Get the cold air. For every 11 degrees you lower the intake temp, you gain 1% in HP. On a 100 HP motor, that would only be 1 HP for every 11 degrees, but at least its something. A short ram will just make more noise. Alot of people like the Js Racing one. They have knock-offs of it on Ebay. I would just get one of them.
90 Civic Si Turbo ZC
Old 02-27-2005, 07:37 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: Aftermarket Air Intake
The knock offs are pretty much the same thing that a AEM is. Only difference would be the construction of the filter. I personally am thinking of doing a home depot one but it just depends on the funds.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 02-27-2005, 07:44 AM
icE_x's Avatar
^ that's what i was thinking also. So get a cold-air knock-off from ebay and then upgrade the filter later, doesn't sound too bad.
Old 02-27-2005, 07:47 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
its pretty much all the same size tube, some have different bends, it doesnt really matter, its mainly the placement and the filter that makes the difference
Old 02-27-2005, 01:50 PM
89hatcher's Avatar
89hatcher 89hatcher is offline
Send a message via AIM to 89hatcher
i would say it all depends on the weather where you live....if you live where its rains a lot i would get a short ram intake...because if a cold air intake sucks up water when it rains it can do a lot of harm to your motor...like bend your rods and cause hydrolock....because of where i live (hawaii) it always rains a lot and i seen a lot of cars that have a cold air intake in there cars and it bent there rods....for example a a shop that i wet to showed me a a bent rod of a brand new nissan 350z and the rod looked like it was at a 45 degree bend...but its up to you an intakes an intake the only difference is the filter...
Old 02-27-2005, 03:38 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
brand name mounts better, generic is good if you know how to weld on some kind of bracket to support the intake. like on my cheap ebay intake the filter scratched up my paint pretty good. but an aem doesnt do that
hey 89hatcher which island u live on ?
Team Lonely Drivers
Old 02-27-2005, 03:58 PM
89hatcher's Avatar
i live on Oahu and i live on a mountain so it rains a lot where i live....
Old 02-27-2005, 06:20 PM
kingpinn's Avatar
kingpinn kingpinn is offline
i have a ebay cai and im glad i got the cold air but i do wish i would have got a aem or enjen but thats just my take
Old 02-28-2005, 07:23 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
You should keep your car clean and stock looking. Just cut out the resonator part of bottom of the intake with a dremel and drop in a K&N filter and call it a day. Honestly, you're better off... and here's why. The battery will move even with the stock bracket thingies when you remove the original air-box. A cold air intake can suck if it's an ebay one, because there is in fact a difference in the shape of the bottom pipe. A cheap one will just face straight down so your filter is vertical, but a good one will have two bends so it bends down and forward toward your front bumper allowing the filter to sit horizontally. I cut a hole in my front bumper so I have air shooting straight in to the intake. I also have an AEM water by-pass thing (which are cheaply made plastic pieces of shit with foam around them) that seems to work. Anyway, it's your call, dude...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-28-2005, 03:16 PM
SiZ's Avatar
SiZ SiZ is offline
If water is a problem where you live, get the AEM by-pass valve.
Old 02-28-2005, 04:56 PM
89si's Avatar
89si 89si is offline
what gains do you get from a ram intake? just better flow and the obvious sound? i have a tenzo intake with a K&N filter, it sure lets people know i have something, but do i really?
89si-
78000kms on original engine.
sub is in.. lights are just about done..
Old 02-28-2005, 07:16 PM
SiZ's Avatar
SiZ SiZ is offline
Barley. Probably about the equivalent of a K&N drop-in or something close..
Old 03-01-2005, 06:01 AM
icE_x's Avatar
gains are pretty minimal on a stock motor - but if you have forced induction i think you would need a better flowing air intake system
Old 03-01-2005, 06:30 AM
Kven's Avatar
Kven Kven is offline
the short ram has better flow but since its sucking in hot air it wont make as much hp as a cold-air. i never seen it in person but ive read and heard of people's cold air still sucking in water with the bypass valve. the highest gain ive seen from a intake is a short ram pipe with a air stack and passenger headlight off(pretty much a "cold-air short ram").
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
