Old 02-27-2005, 01:33 AM
ATMDC's Avatar
ATMDC ATMDC is offline
CV Joints
anyone know how to take off the cv joints from the tranny on an 89 civic?
Old 02-27-2005, 01:40 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: CV Joints
cv joints arent on the tranny, they are on the axles
Team Lonely Drivers
Old 02-27-2005, 08:08 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: CV Joints
eek!
i need mine replaced soon, probably just going to replace the whole axle since it's so old. It shakes and clicks and all that good stuff..
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-27-2005, 08:26 AM
Scott82 Scott82 is offline
Re: CV Joints
You should be able to pry it out w/ a big screwdriver once you get the front end taken apart.
Old 02-27-2005, 03:02 PM
Re: CV Joints
have someone pull on teh axles while the other prys with a big screwdriver
Team Lonely Drivers
Old 02-27-2005, 03:24 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Re: CV Joints
firts you gotta take the outer housing off,
use a hammer,beat it off,then you will have access to the cv joint,real easy...
In the process of B00stin my D
Old 02-27-2005, 03:53 PM
Re: CV Joints
use a hammer to beat it off
what are you talking about
Team Lonely Drivers
Old 02-27-2005, 04:36 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
I think hes talking about actually seperating the joint itself. just an interesting choice of words.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-27-2005, 04:41 PM
Re: CV Joints
yeah but hes talking about taking off the outer cv joint. why would you take that off if your trying to take out the inner joint out of the tranny? it doesnt make sense.
Team Lonely Drivers
Old 02-27-2005, 04:59 PM
well if atmdc would reply, hopefully he'll describe it a little better so we can know what hes trying to do. If hes trying to just get the axle out of the tranny, you huys are right, just get a flathead in between the axle and tranny and pop it right out (no hammers involved lol) If hes actually trying to get the cv joint apart, get the axle out of the car first, then bring on the hammer. help us help you atm
ZC stuff
Old 02-27-2005, 05:09 PM
Re: CV Joints
that wont even work. how are you going to pound out the outer joint while its still in the hub, since the hub doesnt move. and the inner joint can jsut slide out so thats not a problem. the hammer idea doenst even come into play till you have the axle out and then you want to take the outer cv joint apart
Team Lonely Drivers
Old 02-27-2005, 05:24 PM
Re: CV Joints
im assuming he knows how to get the outer joint out of the hub.
ZC stuff
Old 02-27-2005, 05:49 PM
Re: CV Joints
if you have the axle out, the easiest way to change the outer boot is to take the inner joint apart and just slide the the outer boot from the inner joint side. that way you dont have to take apart the bitch outer join
Team Lonely Drivers
Old 02-28-2005, 09:34 PM
ATMDC's Avatar
sorry, theres been a change of plans, me and my friend are replacing a motor and at first we were gunna take the tranny out with it but instead we just decided to take the engine out and leave the tranny in and then put the new engine back in but we cant get the transmision to crack free
