Old 02-26-2005, 09:58 PM
cuberts supra cuberts supra is offline
87 help
I picked up my stang on friday night...my cousin delivered it for me...ive just yard driven it so far. At idle...the idle goes back and forth from 800 to 1200 constantly...never goes to stall or anything like that...just hops. Now my cousin and the guy who sold it to me claim its from the cam...a couple of my friends say its gotta be a vaccum leak...or worse. I thought a big cam made motors idle like that? Im not too big on v8's...the only one i had was in my lincoln..and that didnt get too much attention this side of performance. The motor was also recently installed...so im doubtful that its anything internally. Its also low on gas and sat for about a year..so is bad gas possible? It sounded great when it was on the throttle or revved. Sorry for the babble..but i wanna get this thing road ready asap. again thanks in advance
Old 02-26-2005, 10:49 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: 87 help
has the car been converted to mass air, or is it still speed density?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 02-26-2005, 10:59 PM
Re: 87 help
to be truthfullim not sure..i havnt had a chance to really look at it yet..i know its not the brightest thing...but the rims and shell alone are worth what i payed...so as soon as it gets light out...im gonna look and see what i got...because its an 87 shell...but a different motor installed...i gotta find out what year the motor is from and blabla..but thank you for the response
Old 02-27-2005, 02:32 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: 87 help
Hunting idle, mine does it from time to time. If you invest in a tweecer you can sort it out, if its been converted to mass air.
"Not too big in V8s" Dude, that is where the big power is
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 02-27-2005, 07:10 AM
Re: Re: 87 help
i know..i know...thats why im coming around to the v-8's. Ive always either had a little import or a truck...but this thing is definetly badass...
Old 02-27-2005, 07:16 AM
SkylineUSA's Avatar
Re: 87 help
I run both, as you can tell in my sig
The GTR is BADASS!
Old 02-28-2005, 06:13 PM
Re: 87 help
its speed density still...if i remember correctly he said it has an E grind cam, and head work. I drove it today...runs really good...so im not sure if im gonna really worry about it...but still..if its an easy fix thatd be good
Old 02-28-2005, 07:32 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: 87 help
If it constantly revs and falls like that I would say its the TPS on a SD car.
1969 Cougar
357w & TKO - 475hp
Old 06-02-2005, 12:37 AM
whammymemen whammymemen is offline
Re: 87 help
I've experienced the exact same problem, heck that's all I'm trying to read about now lately. I've done so many things to try to calm that idler down. I've looked over and replaced all the vaccum hoses, replaced the pcv valve, replaced the spark plugs, replaced distributor cap and rotor, replaced o2 sensors replaced tps replaced and replaced the valve behind the tps valve I forgot what it's called....and it has brought me to.....NO WHERE!!!! This has been an on going struggle that has been for a Year! I found on the internet that if you experience this problem to do the plugs, and then check for the entire fuel system, fuel filter, fuel pump. Idle air by pass valve, throttle body, and fuel pressure it should be at 38 PSI with vaccum line off. If it still persists, set fuel pressure to 42-45psi or clean out air by pass valve located off the throttle body. Oh and also to have the fuel injectors professionally cleaned. Sorry it's so long, but I feel for you!!!
