Old 02-26-2005, 06:17 PM
ericpowerstoke ericpowerstoke is offline
won't start
fuel pump works when "hot wired" but no power otherwise
Old 02-26-2005, 06:29 PM
efg
dsfaf
Old 03-14-2005, 01:01 PM
Vanagonfreak Vanagonfreak is offline
Re: won't start
You might want to check the CCRM (constant control relay module) on the LEFT side of the battery. This may have an effect on the operation of the fuel pump. Only one problem: the module has to be tested - on the car - at the dealership; kinda hard to do if the car won't run. The wiring harness is held on by a 5mm bolt, so take that loose first if you remove it.
