Old 02-26-2005, 05:38 PM
JeEpBoY95 JeEpBoY95 is offline
Send a message via AIM to JeEpBoY95
check engine codes
I have a 95 Cherokee 4.0L, AT that suddenly started throwing check engine codes....the codes it gives me are 14 and 15. they mean that my MAP sensor voltage is too low or high and that the speed sensor is not functioning correctly. i replaced my MAP yesterday and i still get these codes after 40 min or so of driving. if anyone has any idea what is causing these errors or how to repair them i would apperciate the input.
Old 02-26-2005, 07:29 PM
Dale Aeppli Dale Aeppli is offline
Re: check engine codes
DID YOU CHANGE BOTH THE MAP SENSOR & THE SPEED SENSOR. ITS POSSIBLE THE SPEED SENSOR WIRES MAYBE BAD OR CRACKED. TRY REMOVING THE GROUND CABLE ON THE BATTERY FOR 5-10 MINS. HOPE THIS HELPS DALE [email protected]
Old 02-27-2005, 12:04 AM
thanks dale...i replaced the speed sensor less than 2 months ago.....
