Old 02-26-2005, 04:50 PM
americansk8er85 americansk8er85 is offline
New crossmember?
I hit a curb, and the wheel bent back, i hit it at an angle. Its the front driver side wheel. so i went and got LCA off a 4dr civic, worked fine, but the radius arm didnt fit right. So after i put the LCA on the wheel is tilted in towards the car from the bottom. Im pretty sure its the front cross member that bent in. I was wondering if a 4dr civic front crossmember would work on my 91 civic std hatch? Its difficult to find a hatch at a junk yard around here in south jersey. If so, would it be worth it to buy an air compressor with attatchments to do the job? any other info would be great.
Old 02-26-2005, 05:36 PM
Scott82 Scott82 is offline
Re: New crossmember?
http://www.crxohio.org/showarticle.php?id=14
This might help ya out some possibly. At least get a pic in your head so maybe you tell if something is bent by comparing the parts in the pic to yours
Old 02-28-2005, 05:45 PM
Re: Re: New crossmember?
yea that didnt help at all lol :-\ thanks for trying. I thought i'd let people know just b/c it says im a newbie, i actually have knowlege with working on hondas, well cars in general. so putting into lamens terms may not help. i still need more info tho
Old 03-01-2005, 10:06 AM
Dastreetracer's Avatar
Dastreetracer Dastreetracer is offline
sup yeah it should work i got a 91 ef hatchback and when i baught it the driver wheel was bent under the car so i went and baught front crossmember and control arms and struts off of a 91 4 door and they all lined up so it should work on ur car..
Old 03-01-2005, 01:23 PM
what about the radius arm? are they all the same?
Old 03-03-2005, 09:35 AM
yeah they all line up and bolt up
