Old 02-26-2005, 03:08 PM
drifter_fan's Avatar
drifter_fan drifter_fan is offline
tamiya clear coat problem
I used tamiya clear coat over Mr.Color datona green and the clear coat turned out dull and cloudy. can I polish out the clear to make it shiny again?
-Julian
Old 02-26-2005, 04:05 PM
freakray freakray is offline
AF Modelrater
Re: tamiya clear coat problem
Did you spray the clear in humid conditions?
Or very cold conditions?
Sometimes you can polish it out, it can't hurt to try.
AF User Guidelines
Old 02-26-2005, 04:22 PM
I used it in the same conditions I always spray in. But it possibly could have been too cold for clear. It's winter and I spray in my basement.
Oh, how long should I wait to polish it out?
-Julian
Old 02-26-2005, 06:03 PM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
I left my clear for two weeks before pokishing if this helps
Old 02-26-2005, 06:46 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Yeah, polihing should do the trick. Give it a week or two to cure, once you're satisfied the clear is thick enough to polish.
PHOTOBUCKET SUCKS
Old 02-27-2005, 09:15 PM
Thanks, i'll give it another coat or two and then I will polish it.
-Julian
Old 03-24-2005, 12:09 PM
zanthrax's Avatar
zanthrax zanthrax is offline
Cloudy clearcoat points towards a too thick coat of paint.
Old 03-24-2005, 04:14 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Zanthrax is right, and adding more coats will not help, it will just seal it in.
Wait a couple days, if it doesn't become clear, strip and start over, or sand through the clear to remove the cloudy parts and re-shoot. I'd probably strip it... - Mark
Old 03-24-2005, 04:38 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Best thing would be to strip.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 03-24-2005, 04:50 PM
Vric's Avatar
Vric Vric is offline
I had a similar problem yesterday (with smoke paint been too dark on carbon fiber)
Rubbing many time with automotive coumpond removed all the smoke paint for me and didn't hurt the CF decals.
you might try it before stripping everything
