Old 02-26-2005, 02:32 PM
bigal0043 bigal0043 is offline
S-10 Blazer start problems
i have a 91 s-10 blazer 4.3l anyways... it is having a weird starting problem.. like if it is cold it will almost always start fine.. but after u drive around for a bit then let it sit for like 10 mins it takes a while for it to start... it will just keep on turning without anything happening then after like 30 secs it will start but start really rough then after another second be fine... any ideas?? i was thinking the fuel pump was bad but i dont want to have to take the tank out and replace unless i have to.
Also i replaced fuel filter...
Alex
Old 02-26-2005, 02:36 PM
sykopenguin sykopenguin is offline
Send a message via AIM to sykopenguin
Test your fuel pressure and post the numbers back here....
Yes My truck is a piece of crap ....I know.
Old 02-26-2005, 04:14 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: S-10 Blazer start problems
Yip, check your fuel pressure and check your battery voltage both when running and when the engine is off.
Test the voltage with a voltmeter, NOT the dash gauge.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-26-2005, 04:20 PM
how much is a fuel pressure gauge??
Old 02-26-2005, 04:43 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Also check and make sure the injectors are not leaking after the engine is shut off.
Old 02-26-2005, 06:09 PM
BlazerLT's Avatar
AF -Advisor
You can rent one from Autozone.
