Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-26-2005, 02:19 PM
unknownluder69 unknownluder69 is offline
ideal compression ratio
I have a h22a1 (VTEC) engine in my 4th gen lude and am looking into buying some new pistons and sleeves. I have future plans of turboing it but for now im going NA. i am getting cam gears and cams from crower and also new valve springs and titanium retainers. I dont know wat the stock compression ration is but I need to know what it needs to be in order to get the best results and performance out of my mods. any help appreciated!
Old 02-26-2005, 03:33 PM
OonePrelude OonePrelude is offline
Re: ideal compression ratio
10:1
2001 Honda Prelude DOHC VTEC
AEM CAI
Custom exhaust w/ Fireball Muffler
Old 02-26-2005, 03:36 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Well, if you choose NA pistons (usually around 12.0:1), you can't turbo it later down the road. Much like if you chose turbo pistons (~8.0:1), you'll have little power without a turbocharger. You have to pick one or the other.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 02-26-2005, 03:48 PM
If you're getting cams, make sure they can also be used for boost. Otherwise you'll end up changing them when you do finally go turbo. Allthough I don't believe it's possible to get cams that fit both application. With NA, it's good to buy cams that have overlap. However, having overlap on a turbo application is not such a good idea. It's harder to pressurize the cylinders.
AEM CAI
