Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-26-2005, 03:09 PM
Darkcloud9
Guest
Posts: n/a
Is this a good Turbo?
I Was considering putting a turbo on my 95 LS, I found this compleate kit but i wasnt sure if it was worth it and if there is anything else i need to replace prior. http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT. Would i be ok with the heads and cams that I have stock?
Old 02-26-2005, 09:45 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Is this a good Turbo?
That kit is not a complete kit, you would still need some sort of fuel management. Hondata, 255lph fuel pump and some bigger fuel injectors ( size depends on boost) would do just fine with that setup.
And yes you will be ok with the Head and cams that you have on there now. However you would want to get a compression check and a leak down test before deciding to boost. Get the tests and give us the numbers and then we can go from there.
Old 02-27-2005, 08:31 PM
kevin85193's Avatar
kevin85193 kevin85193 is offline
Send a message via AIM to kevin85193
Re: Re: Is this a good Turbo?
http://www.honda-tech.com/zerothread?id=1097918
that will give u an answer. do go w/ a crap kit, or u get crap results. I'm piecing my kit together
so sleep secure...
and rest assured that you're beautiful
...with trigger pulled
