Old 02-26-2005, 12:02 PM
MSFIDC MSFIDC is offline
Question 1996 Silverado A/C drain
I can hear water moving behind the passenger dash when I make turns and brake. I really think its condensate from the A/C. The truck sat while I was deployed to Iraq and I don't remember hearing it before I left. My question is....WHERE IS THE DRAIN! I have talked to people that make it sound like it is RIGHT THERE on the firewall or underneath but I looked all over for it. I think its clogged and needs to be blown out.
Thanks!!
Rich
Old 02-27-2005, 12:08 PM
70camaro 70camaro is offline
Re: 1996 Silverado A/C drain
Sounds more like coolant in the heatercore. This is common for these trucks. Check you coolant level. I dont know where you are, but unless it's hot there, and you'r running the a/c, it wont build up fluid.
Old 02-27-2005, 02:18 PM
nineball481's Avatar
nineball481 nineball481 is offline
Is this sound a warning of the heater core going bad? Or, is the sound normal to hear? How do you make it stop?
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 02-27-2005, 08:41 PM
Coolant level
yeah, my level was low so I filled it. It's still pretty cold here in Virginia and my heater is blowing good and hot. Now worries or just the beginning????
Old 02-27-2005, 09:27 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Well, if I were you, I'd be wondering where the coolant went to. If there is no coolant on the driveway, it's not in a good place.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
