Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-26-2005, 11:56 AM
paulgreen paulgreen is offline
Send a message via MSN to paulgreen Send a message via Yahoo to paulgreen
Repairing Aerial?
Is it possible to repair the factory fitted aerial on the Grand Cherokee? if so, how do you get it out?
My motor is spinning in it, but not pulling the mast down.
Old 02-26-2005, 05:08 PM
navyjo23 navyjo23 is offline
Re: Repairing Aerial?
it happened to me, i broke mine in a Car wash last month, I took it out by pulling it and then got a new one from teh delaer and just put it back in ant turn on and off the radio, the motor if it is working will pull it down.
Old 02-26-2005, 07:17 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
I broke my antenny off awhile back while wheelin' and tried to replace it like NAVYJO23 mentioned but was unsucessful - so I need to take the whole motor out to take it part b/c there is some of the rubber mast stuff inside of the motor, and I think this is keeping the new mast from going down all the way, altho I cannot find the electrical connector and antenna where it enters the inside fo the vehicle. My antenna has been going whacky for awhile now, every once in awhile the motor runs constantly (up and down), so I just pulled the RELAY out (inside the glovebox - false bottom, 1st BIG BLACK RELAY in the back, toward the driverside) - just incase you want to remove it as well until you get the antenna fixed.
ALSO IF ANYONE KNOWS EXACTLY WHERE THE ANTENNA WIRE/ELECTRICAL CONNECTORS ARE LOCATED AT, BEHIND THE KICK PANEL ON THE PASSENGERSIDE. let me know. HAYNES and FSM do not show it, they show it for the standard mast but not power antenna mast.
